Assuming that it is a new dishwasher, it should be supplied with a paper template to show you where to fit the mounting plate to the back of the door. As per @flameport 's post, you will probably need to cut a horizontal notch into the plinth.
Most dishwashers only have 3 feet. The solitary foot at the back can normally be adjusted from the front with a screwdriver. Often the strength of the door closing spring can be adjusted via screws at the bottom/front of the machine.
