interlocking retaining wall systems
19 Jul 2011
hi does anyone know of any companies that supply interlocking retaining wall systems in the uk and the approx prices per block.
as i am looking for a better/cheaper system to the traditional brick build wall.
cheers
jon
tobermore, acheson glover, marshalls do one too i think. Most of the major players have a few variations, They tend to be priced by the linear meter.
For example a basic tobermore block like secura lite is 80mm high so to build a wall 800mm high you need 10 courses.
If your wall is say 5 meters long then you need 50 linear metres.
The secura lite is about 4.50 a metre
hi many thanks for coming back to me but these are not quite what i am after
i am after a free standing gravity retaining wall system with a height of 1.8m +
cheers anyway
jon
Most of these type of walls are suitable for use up to and above that height but need proper designing.
See here
You will not find any company making one that say you can simply build it to 6 feet without proper engineer input.
Large retaining walls 4 ft plus are expensive but for good reason as they can be very dangerous if badly built
