Hello.
I have been experiencing an intermittent failure on my Glowworm Ultimate FF30.
In a morning, the boiler comes on fine on the timer and all radiators get warm fine.
The timer then switches the boiler off after 3 hours and comes back on in the afternoon. It works for about an hour and then the fan and burner fail to light. The timer remains on. The water pump still works.
The next day, this repeats or sometimes works ok into the evening before failing.
My plumber has serviced the boiler and cleaned the pilot. Otherwise it seems fine.
We have reviewed the neon lights and 1 and 2 are lit which seems to indicate a pressure fault?
However, we have noticed something else while looking for the fault-when removing the cover, the fan came on. To me, this means a possible electrical fault? The burner did not come on.
Then today, the same happened as I waggled the thermostat/fuse controls and I did it again next to the air inlet (I think) and the burner lit.
My plumber is going to replace the pressure switch but im wondering if its something else?
Any thoughts appreciated.
