Internal door flap (brass) needs cutting, what kind of service can do it?
26 Dec 2012
London
I have a good quality brass internal door flap / tidy / whatever it is called, and it is too wide. It needs to be cut, so that it is an inch more narrow. What kind of professional service should I search for to do a good job? nb I am in South London.
In case anyone wants to know, it is a very good wooden door, about eighty years old. It has a very small "rectangular hole" for letters, but for whatever reason, I don't seem to be able to find something with insulative brushes/flap that fits - and I have searched a lot. So, I found a company to make the brushes part (received and glued on), and found an oversized flap. Thanks.
16 Jun 2006
London
A carpenter will be able to make the letter box opening bigger but it sounds like you want someone to cut down the flap.
Can you provide photos?
26 Dec 2012
London
I can't now because I've glued the brushes over it. Basically, the hole in the door is 5 inches wide, 2 inches high. the door thickness is just under two inches. Because of the panelling on the door, the max width of the flap is about 10 inches.
I did actually order a custom-made flap, but I didn't measure it correctly. It took them 6 weeks to deliver, and I'm sort of reluctant to use them again.
