Internal insulation on external wall
24 Mar 2014
London
Hi. I live in a Victorian terrace house. I've got builders starting in a week. They're going to strip some damaged plasterboard off an external brick wall, which has been applied by dot and dab. I had a survey recently and the surveyor recommended adding insulation.
This is the product I thought I'd order:
Does that look like a reasonable choice? Grateful for any advice. Thanks.
Product is ok and you need to follow the data sheet application.
I guess you don't have a cavity wall, just a single skin?
CharlieDIY on YouTube has done several videos trying out different systems.
Maybe look at those and decide which is best for you.
You can also phone the technical helpline for the product
Thanks. Yes, it's just a single layer - not a cavity wall.
Looking at CharlieDIY's comments on u-value, it looks like the 62.5mm Unilin Safe-R SR/TB achieves 0.33 on solid brick. So I think I'll need to get the 72.5mm one, which brings it down to 0.29. It's a shame to lose to much much space, but I guess another 10mm won't hurt!
Thanks for your help.
