I have been set a task to do within the home, I feel confident in carrying it out after reading a few posts on here and looking in the diy manuals.
The partition itself is to split a room in two, no door, more of an archway but without the arch.
3 foot partition x 4 foot opening x 2 foot partition with about a drop of 6 inches above opening. (7ft from floor to ceiling).
Firstly, my questions was what timber size would be most suitable for this job, some posters have indicated 3 x 2 others 4 x 2, then deciding on planed or unplaned.
Do I need more noggins if I use 3 x 2 and if so what space should I be putting between each one.
My main concern was, as the ceilings beams do not run parallel to the partition I am going to construct, how do I find each beam in the ceiling to screw the top joist into?
What is the correct order for putting up joists?
What screws should I use, how long, different types for each surface, the floor and wall is concrete.
With the plasterboard, will it cover the exposed joist wood around the opening as my plan is to put some quality wood around it.
How long would it normally take to do a job like this? Does it require 2 people?
It may sound as if I'm not confident by all the questions, but once I have the answers I'll be raring to go.
