Semi-detached house built in the 1930's. All houses in the area are of the same construction.The ground floor has a brick cavity wall which has been insulated with polystyrene beads. The loft is insulated to current regs. The first floor however has a single skin which is not insulated and is internally plastered. The external wall of the first floor has a rendered/roughcast finish painted with masonary paint, therefore not sure what the first floor wall is built of. There are no obvious signs of damp anywhere.
What is the best method of internally insulating the first floor without using up too much space? Celotex bonded to the wall then battened and boarded, or an insulated studded wall to create cavity and boarded? Cheers!
