hi all,
i've had some plans drawn for a rear 2 storey extension which will be 5m wide and go back 2.5m. the extension will be built between my neighbours external wall(he has already extended) and my garage wall.
the plans show that i will have a strip foundation for the 5m cavity wall that will run between the two existing walls, which i understand.
**Then i am to lay the floor slab between the 4 walls and build the internal side walls on top of the slab with lightweight blockwork.
(there will be no joists coming off these internal walls, they'll just form a cavity between the existing outer walls)
will the slab take the weight?
