inverted loop radiators
22 Sep 2007
HI FOLKS - NEW TO THE FORUM.
Central heating boiler was leaking, going to cost a fortune to repair/renew so took it out and welded up the leaks.
Refitted and flushed system through boiler and bled the system.
Everything seems to be running except for two radiators which I believe are on an inverted loop. Despite trying to bleed them they still don't want to get hot.
Any advice?
Brilliant! - warm as toast now - I've been puzzling over that one for ages - shows the beenfits of being able to share someone else's wisdom. If I knew how to use the emoticons I'd put in a big smiley face - thanks
JohnD!
