Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
You can generally only buy iron on wood veneer edging strips that are pre glued.
It is possible to buy "glue film" which is like a thin polythene sheet that goes between the substrate and veneer. It works best with a heated press or in small areas if using a domestic iron, on large surfaces you just can't get the heat into it by hand.
If the fire surround is for a working fire I would be worried about the heat affecting the glue bond.
You can by "flexi veneer" which is edge jointed and laid on a paper backing, this can be fixed with contact adhesive if you don't have a press, but you need a nice even layer of adhesive.
I use a vacuum press and traditional veneer stuck with Titebond II
