Some gas engineer don't want to waste time do the calculations and just go for the bigger size (bigger job maybe?)
Last, but one, boiler swap, the engineer was insisting it needed a new pipe, run on the outside surface, all the way from the meter, around two walls of the house. It would look horrible. The new boiler, was a size down from the original, the pipework was all buried, and properly calculated at install. I redid the calcs, sent that potential installer packing, and found another. The 22mm pipe was fine for that install, and the subsequent one too.
