Is earthing wire necessary on communal Sky dish set up?
20 Jul 2005
Worcestershire
I live in a block of 12 purpose-built apartments that are served by one satellite dish through a splitter box. One of the other tenants wants to upgrade his Sky subscription to Sky Q but the Sky technician won't touch the splitter box because it's not earthed. Is this right? The original equipment was installed straight out of the box by a Sky tech about 8 or 9 years ago.
With TV/radio/satellite reception and distribution systems in blocks of flats, yes, the system does need an earth connection to the building's main earth terminal (MET). Where the signal wires connect directly to the switch, then the switch itself should have the earth connection. Other installs might use a bus bar to make a common earth, so either that or the switch can be earthed as it serves the same purpose.
The connection to earth must only be made by a qualified electrician. The chances are that the Sky installer isn't qualified.
Maybe the system is earthed, but the installer missed seeing it; or it's not earthed at all, in which case he can't do anything with it without opening himself up to a heap of trouble for the liability. Either way, he's playing it cautious because that's the safest option.
If this or any other reply was helpful to you, then please do the decent thing and click the T-H-A-N-K-S button. It appears when you hover the mouse pointer near the Quote Multi-quote buttons. This is the proper way to show your thanks for the time and help someone gave you.
