Hello All, I'll try to keep this brief.
I have a Baxi (Potterton HE) combi boiler, HW is fine, CH is not. The hot water for CH doesn't even make it past the elbow in the outgoing CH pipe - which at this stage is still even inside the boiler panel. Consequently the hot water running through the CH system takes its shortest route back to the boiler and the burner cuts out after about 1 minute, thinking that it has reached temperature. Of course it hasn't because the water isn't flowing through the entire radiator system.
Long story short, there seems to be a blockage in the pipe running from the boiler down to the heating manifold. Bearing in mind we've got underfloor heating (flat is barely 3 years old) so the point where the suspected blockage is, is physically higher than all the underfloor radiator pipework. A power flush was recommended and from what I've been reading, this can either be undertaken by a pro for anything up to 500/600 pounds, or, with a little bit of know-how, done by oneself using a product such as Fernox DS-40.
So, the questions are:
- Is this a relatively simple procedure?
- Is it legal to do it by oneself (I know this is a fascist state these days but I'd hope it would be)?
- Is it safe?
Potterton won't touch it because "the boiler is working fine". Go figure.
Sincere many thanks in advance for any info.
Steve
- Is it safe?
Steve
