I have a modern brick clad timber-framed house with a top room up in the (pitched) roof which has loft spaces to either side (ie behind the side plasterboard walls of the room) and a loft space above (see first slightly rubbish chart attached)
. I want to create a larger door into one of the two side loft spaces by removing two of (around eight) of the the vertical struts that make up one wall of the room (plasterboard). Is it acceptable to remove two single struts and make a timber lintel to span the gap between the adjacent double struts (see second slightly rubbish chart attached). Sorry I can't attach photos right now as I'm not at the property.
Mike
Mike
