Is it worth changing a radiator?
16 Jan 2012
Lancashire
We have a 200cm wide x 40 cm radiator in our front room. No other radiator in that room. It is a single panel radiator. Is it worth the money changing it to a double panel radiator that's the same width but 50 cm high rather than 40? Would it make the room warmer? It is under our front window so we cannot go to 60 cm high as it's right under the window sill
Yes, you'll more than double the heat output if you put a double panel, double fin that is 25% larger (50cm vs 40cm high) than what you have now.
Yes it will be warmer. It will be worth it. Depending on the make like stelrad you can get a double + which has extra fins inside compared to a normal double. I think its called a P+
Not sure if we can ask this on a forum but any ideas on rough price? We also have 2 other single panel radiators in the house that are smaller. One is 180cm wide x 60 high
