I've got no heat or hot water from my Chaffateaux Britony Combi boiler.
I power it on & ask for HW or CH (same symptoms happen) Pump starts ok, but fan does not. Eventually it displays an error code meaning the "air pressure switch is not responding with the fan on ". But the fan is not on, so it wouldn't trigger the switch !
If I supply the fan with 240V manually (i.e. with an extension cable and reasonable care), then the air pressure switch responds and the boiler gets passed that.
But then...it doesn't power the piezo ignition. So then the boiler locks out as it knows the gas hasn't been lit
Both the fan and the ignition come from the PCB and neither seem to be working ok or quite as I expect - but then I'm not an expert.
I would be grateful for a bit of advice/experience on these things. PCBs are too expensive, and non-returnable if I buy one I don't need ! Any quick fixes to try ? I have a soldering iron if need be...
