Hello all.
I’ve recently had a new boiler fitted and the fitter has explained the concept of the pump overrun facility.
It all seemed to make sense until I looked at the position of the components involved. The boiler, pump and bypass valve are all very close together, within about 2mts of pipe for the complete circuit. Basically, the over run doesn’t remove any heat from the boiler (or very little) once the boiler has stopped firing as the heat hasn’t got anywhere to go.
Looking at the situation from a layman’s point of view, would it not be far more beneficial to hold the 2 port zone valve open for the length of time that the pump overruns? I’m certain I can draw up a circuit to make this happen, and also to keep the switched live to the boiler open (to stop it firing back up) while the pump is overrunning.
Just how important is it to remove the residual heat from the boiler once it has stopped firing? Am I wasting my time / money with this modification?
Any thoughts or comments would be much appreciated, thanks.
