Thank you all for your help and comments. I have now fixed the problem.
It turned out there was considerable amount of debris in the double check valve. There was a piece of gravel that was blocking at least half of the flow, and a chip of wood that was blocking the other half. Added into the mix was sand, and some black material resembling the stuff found in water filter cartridges, except these black particles were bigger like sand grains. After I replaced the double check valve, and ran the taps, there was quite a bit of the black particles coming out of all of the taps. Then it was cleared after a while.
I am pretty there are a lot more debris in the mains supply. But I didn't have the right equipment and parts to run the mains clear. So after a bit I imagine my new valve will also get blocked. That's something I will deal with next time.
For now I have more or less the full water flow back. But I have a few more questions I am not sure about:
1. The old double check valve had one of its valves physically removed by the original flat builder/plumber. I can guess that was done to reduce restriction. Now that I have put in a normal double check valve, would I have introduced more restriction ? What is the restriction difference between a single and double check valve anyway ?
2. I didn't have any tools to remove the old pipe olives. So I just reused the old olives and check valve nuts. The original valve was chrome with chrome nuts. My new valve was brass. Are the old chrome nuts chemically compatible with the new brass valve or will I get a bad chemical reaction at some point ?
3. Although the water flow is now great, at least for one tap. While the large bath tap is open, the flow on other taps are weak, but better than nothing anyway. What is the normal expected flow rate for a straightforward 15mm pipe-work ? I still haven't measured my flow rate yet. But I am interested to see how that compares to the expected rate in an ideal circumstance.
