Would you mind listing the deviations you saw
I’m looking at this document; it’s not entirely clear if it’s the right one:
Hmm, it seems I can’t copy-and-paste from it but here are some approx quotes and other notes. (To re-iterate, I’m no expert.)
“The orientation of the cylinder must have all key connections …. uppermost”
“Connection to expansion vessel” (pointing to a port on the inlet monobloc that is not used on yours)
“Mount the expansion vessel … above the cylinder”
Your balanced cold connection is not used (do you have a pressure reducing valve on the cold supply elsewhere?)
I cannot see a tundish. Where does the pressure relief pipe go?
