Traditionally in Britain, down was on, this is still the case with lightswitches, FCUs, DP plateswitches, Switched sockets etc.
However on devices designed to European standards, particularly the Din-rail mount devices (MCBs, RCDs, RCBOs, switch disconnectors) used in modern CUs, down is off.
Even more confusing is the retro-fit MCBs for wylex standard units, which seem to follow the European convention, even though the main switch on the unit usually follows the british convention.
