Issues with Hive
2 Dec 2018
Hi All
Any experts on Hive here, I have had the Hive thermostat about 3 months now and intermittently like this morning its set at 16.5 degrees at 0830 but the radiators are on and the app shows its set to 19 degrees. I spoke to Hive support who reset the system but didn't properly understand my problem kept going on about ambient temperature but surely if its set to 16.5 its shouldn't come on if its higher in the house, I dont have time today to spend another morning with them so I can do it later in the week but I wondered if anybody has any ideas. Thanks
Hive single channel or dual channel, what boiler ? any other controls timers etc ?
Dual channel, no other controls and boiler is Vaillant Eco Tec plus 615
It’s possible that your heating zone valve is passing ,so when it’s on for hot water it seeps into the rads
Dont think its that as the Hive shows a target of 19 degrees , I think its faulty tbh but gotta get Hive support to sort out or agree
yes you have an S plan, most likely that you have a faulty zone valve than a faulty Hive, Hive is simply a switch, not much to go wrong
Are you sure your stat isn't set in 'stand-alone' mode?
