Jaguar 23kw
On returning from 2 weeks away I turned on the shower and had no hot water. Looked at the boiler and it showed low water pressure, I topped it up (shower still running) and then it went off and displayed the f1 error.
I assume that it tripped the overheat thermostat. I pressed the reset button on the thermostat (which didnt really move) and pressed reset on the panel. Still no luck. Thought it was maybe still to hot and not resetting so left it a while. tried again and still no joy.
I removed the thermostat and there seem to be a lot of play in the button. I tried to trick the boiler in to starting by shorting the thermostat wires but still get no flame.
There is a spark, the fan is running, there is no blockage in the flue.
Should I just get a new thermostat and try it?
Sorry for the essay, just trying to give as much info as possible.
Many thanks in advance
Mike
Mike
