So in tacking the job in my other post, I’m wondering if I could potentially solve another problem.
The garden shed, garage and outdoor light no longer work and the faulty cable was taken out of the CU. New 1.5mm armoured cable has already been run from the shed to the house but to get it to the CU, chipboard flooring would need to come up, and that hasn’t progressed.
However, where the armoured cable comes into the house is a 32A ring which is only for the sockets of one bedroom.
I’m wondering if it would be possible to break into the 2.5mm ring and join the 1.5mm cable to it?
There is an FCU where the armoured cable enters the shed, which then runs on to the shed light, outside light and garage. There’s also a socket in the garage, which is never used. The CU is RCD protected.
Not sure if a) it’s good practice or b) I’d need an electrician to do it. Thought I’d ask as it would avoid the hassle of getting a chipboard floor up.
Thanks.
Thanks.
