I realise this question has been asked numerous times in various forms, but I am still confused. The water enters my house through a metal pipe of some description (not copper and not lead). How can I determine what this pipe is made of? It is around 7/8" in external diameter (I can't measure the internal diameter as I haven't dismantled it yet although from other posts I am assuming it will be 3/4") and screws together along it's length.
Anyway, my questions are as follows:
1. I am guessing the pipe is made of steel of some variety? Is there an easy way to determine whether it is galvanized or not?
2. I am confused as to whether I require a dieletric union at the join between this pipe and the rest of the pipework in the house which is copper. Is it true that such a union is only required in systems where the water circulates, i.e. a central heating systems? If I do need to fit a dielectric union to prevent corrosion I assume I will need to bridge the union with some kind of earth bonding to ensure earth continuity. However surely doing this will defeat the object of installing it in the first place?!
PLEASE HELP ME!!!
Many thanks,
Ben.
PLEASE HELP ME!!!
Many thanks,
Ben.
