Joint compound
24 Feb 2014
London
I was going to ask...
What material do you use to skim a wall, whether it's fresh plasterboard or a previously plastered wall?
...and what is mud ?
But then i read this: http://en.wikipedia.org/wiki/Joint_compound
Is this always used to skim a wall no matter what the type of application?
Can you use this instead of 'filler' for filling holes and cracks ?
I generally use multi-finish
In the UK it is what you get underfoot whilst walking in the rain!
In North America it is the term they use for jointing compound
You do not skim a wall with jointing compound, it is used when joint taping ideally with tapered edged boards the application of this is used where boards are joined/butted up, also used over thin coat beads on external angles and window reveals, plus you will spot the screw heads with it.
It would normally take two over three applications to fill the joints out, and would be sanded after each application has dried.
You can providing the cracks are not massive, it would also help prevent the crack reappearing if you taped over the cracks prior to applying this.
