Hi all
I'm fitting in a new sink which is all going ok. But the drain pipe running through the wall + down into the external drain is proving a bit of a pain.
I've got a basic 'L' shape to the run, with a 45 degree elbow on the corner. Trouble is i've got a bit of an incline running from the sink trap to the elbow, but then i've got the downpipe running at a slight angle aswell. It's a basic push fit elbow + i'm getting constant leaks b'cos of the angles of the pipework..........question is can you get some kind of 'dry hard' compound sealant i can use on the push fit elbow? I don't want to use a silicone sealant + i want it to last.
Cheers
Cheers
