I need to run some 2.5mm T&E in an upstairs bedroom.
The floor joists are 200mm deep, 50mm wide, 4240mm span and spaced approx 470mm.
The floor board I have easy access to is about 200mm from the span end and best placed for where the sockets will be.
I was thinking I only need to drill a smallish hole (e.g. 12mm dia) on the joist centre line, to thread the T&E through.
But reading the LABC guide fragment I found on the net, on where to make holes, seems you need to be much further away from the edge when drilling holes as opposed to making a notch. But the hole I need is much smaller than their 50mm max dia for this depth.
I'd prefer not to have to lift up another 2 or 3 boards - hoping for some advice from the experienced!
