kenmore dishwaher not draining
23 Jan 2004
My dishwasher will not drain. At least two inches of water is left at the bottom after the cycle ends. It sounds like it is trying to drain unsuccessfully. If something is plugged or preventing it from draining, how do I fix this?
Thanks for you help in advance~
Tammy
sounds like it might be blocked at the bottom there should be a drain way which unscrews and you can then try to unblock it you could also try and pour some weak drain unblocker down there.
