Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
i have a keston c55 boiler which keeps flashing E65 code after a couple of hours afterwhich i need to reset . Any solutions? Code is not in manual and keston say have never heard of this code........ useful as ever!!!!!!!!
Find a Skip and put your pi;le of carp in it!!
if the manufacturer's have not heard of E65 then how can we help? I would suggest that they might like to attend to your boiler so that they can learn? and in future would know what an E 65 code actually means?
We often encounter codes the manufacturers done list.
When I asked me friend to enquire about a code which was not listed we had a good laugh when the answer came back from the design team as " boiler fault, other".
Often unknown codes result from otherwise unknown engineers settings or from a faulty PCB.
Perhaps someone will have seen this before, otherwise an engineer would have to check all the operational parameters which the boiler measures ( which are not many in the case of ther Keston ).
