i've looked in the archive, but can't quite find the answer...
it's a worcester greenstar he plus boiler, and occasionally it overheats. the scenario last night was this: a bath being run upstairs [no problem when done on its own] + i started doing the washing up downstairs: so extra demand on the hot water.
various crunching pops emitted from the boiler. the temp read 113 degrees on its little screen. this fell quickly when the water was turned off, and everything was ok after. normal peak temp for running the bath was 65-75 degrees.
it's serviced regularly, is fairly new, had a valve changed when this problem occurred once before..
any views on the cause? scale? thermostat? i'm not sure i want to try experimenting, and trying to make it happen - it's an alarming noise - but is it possible that the system was getting its 'flow demand' from the kitchen [ie low] and high 'temperature demand' from the bath? & therefore superheated water..
