Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
when temp rises to max the gas valve mods down to keep temp below cut off point.if min gas pressure on gas valve isnt set properly it cant mod down enough , so cuts off until temp has reduced.generally happens on weak flow rates on cold main.
thank you for all your help yesterday. How can i rectify this fault ? I believe it is the heat exchanger as mentioned, can I prove this and then how do i de-scale it best?
