Hi all,
I'm reboarding my kitchen ceiling at the moment and just wanted to check on the below before proceeding further.
Firstly, the existing ceiling was double plasterboarded. The reasons for taking it down was due to part of it sagging as a result of a previous leak (self inflicted- accidentally drilled through CH pipe from above), and a lot of rewiring required.
I thought I may as well go for a double layer of acoustic plasterboard as we have a bedroom above. I did check the weight specs and it is 2.5kg more per sq m (10.5kg per sq m versus 8kg per sq m for standard). thus in the grand scheme of things I thought negligible. I am however now doubting myself. Floor joists above are 200mm by 47mm. I can find a lot of guidance regarding what weight from above but am struggling a bit to find anything regarding what you can hang off it below. It will obviously be evenly distributed across a 4x4m room.
