Hello All,
We are currently redoing the Kitchen, following some moving of internal (non load bearing) walls.
The Kitchen has been designed and is on order for the end of August, but now we have the challenge of working out the flooring.
The House is a 1960's Semi House with a concrete slab base.
The Kitchen is now half, Tiled Floor, (over some old old vinal / tiles) (the original Kitchen floor) and half Parquet flooring (5block squares). (and where the wall originally was there is approximatly 5cm differences in height (from the Concrete floor to middle of the parquet flooring)
The question is what to replace it with we have about 20sqm, and a budget of all in about £70 - £80 a sqm, and looking for a low maintaince,
I want to move away from Ceramic tiles, as they are COLD, although SWMBO wants them, not really interested in the underfloor heating option due to running costs.
I have looked at Polished Concrete floors, but I am not sure the finish is good enough, or suitable
So looking at our remaining options so it seems its tile / slate effect kitchen Laminate or "luxury vinal" (Kandean or Polyflor)
I like the looks and feel of the vinal tiles, but after reading this post all be it 3 years old (unless things have changed since then)
//www.diynot.com/forums/viewto...&start=0&sid=9e30431f5c3a7e07a3a1c87efb767ecb
I was hoping one could just level the floor then lay this over the top but it seems not the be case, so thats probably going to be very costly, and over the budget we have, I have also heard reports that it scuffs easily.
Is this true?
So from ease of use it seems kitchen tile effect laminate will be the best bet, but will it be robust enough for a family of 4, including a 1 year old, and a cat.
Will it be good enough to level the difference with latex then lay the laminate over it?
Help????
What would you do if you where in my position?
Is this true?
Help????
