Kitchen install - End panels next to built under double oven
11 Jan 2011
Hertfordshire
After realising I spent a small fortune on end panels that were almost completely concealed on my previous kitchen, this time I'm working through the plan and removing all unnecessary items before I okay the design.
One thing I'm not sure about, the design has specced an end panel either side of the built under double oven. I initially thought I'd just remove these. Would it cause any issues to attach the oven runners directly to the sides of the carcasses? What is usually done here? The panels are not required to support the worktop.
Cheers,
Dan
Does the double oven fit inside an oven housing unit?
If so the end panels are not required.
You need the panels, as the oven fits over them at the front where you screw it in.
