Kitchen Sink Waste
5 Sep 2012
Kent
Hello,
I was just wondering if someone could help me please!
I am changing the waste underneath my kitchen sink, as I've installed a dishwasher and needed a waste that I could connect both the dishwasher and washing machine wastes to.
I bought this:
https://www.screwfix.com/p/floplast-dual-sink-wash-trap-white-40mm/33137
However, after connecting it to the sink waste successfully, the end of the trap that connects to the waste pipe (the pipe leaving the kitchen) is too high up, so I can't connect it up.
My question is, could I use something such as this to solve the problem:
https://www.screwfix.com/p/mcalpine-flexcon6-flexible-waste-pipe-fitting-white-40-x-210mm/9808v
Or should I be getting something else?
Thank you!
CBW
26 Sep 2019
North
You shouldn't be trying to connect higher up, that's just asking for smelly trouble. Post a photo of your outlay and we can advise better
N
Newboy
I have uploaded some photos
Avoid the flexible waste - it will fill with gunk from the sink waste.
Two compression elbows and a short length of 40mm waste pipe will enable you to link the trap and the waste pipe.
https://www.screwfix.com/p/floplast-wc11-universal-compression-waste-bend-90-40mm/35203
https://www.screwfix.com/p/floplast-solvent-weld-waste-pipe-white-40mm-x-3m/44310
or, and better, use solvent weld (assuming that your existing waste pipe through the wall is suitable)
https://www.screwfix.com/p/floplast-bends-92-5-white-40mm-5-pack/92756
Couple of observations:
1) Your old set up didn't have a trap
2) Your dishwasher waste pipe needs to rise up to the level of the underside of the sink before dropping into the waste connection - otherwise the waste water from your sink will flow back along the dishwasher waste and fill the d/w sump with sink water.
8 May 2017
How much lower does trap need to be to meet the waste pipe that exits the wall ?
You may be able to just use a trap extension.
3 Mar 2005
Surrey
You could look for Y connector for your existing set up - i.e. Two into one either replaces the existing connector. Eg Mcalpine twin sppiggot or viking hat connector !
Of course you must ensure both waste pipes go high before going down to the WM or DW to stop backflow or crossflow.
Best to persist with your trap and try some sort angle bends back to back.
