OK pushed my kitchen units against the wall and there is a gap as the wall in uneven vertically as well as horizontally:
Assuming my worktop will be 620mm and the kitchen units are 600mm (605mm if you factor in the gap):
What is the best course of action to get a straight row of units?
Either: chisel out the wall, or cut the back of the units?
Also why do units have that thing sticking out the back? Surely this was made for cutting down to size?
The worktops they sell at Wickes are 600mm, same as the units. I always thought it was normal to leave a 20mm overhang so if one had a 600mm worktop the units would have to get cut down at the back to give an overhang right?
I was thinking of taping a string to the floor at the front of the units then cutting the units at the back so that the fronts line up with the string, is this a good idea?
Thanks.
Thanks.
