hello all
Just after a bit of advice, I am having new kitchen work tops fitted, they are just loose fitted at the moment and the joiner has had to go to another job for a couple of days, however the mitred joint (I believe it's known as a Masons Mitre) is tight at the front end with a 1mm gap at the wall end, I can't see how this can be made to fit so there is no gap, is there a way that the gap can be filled somehow so as it is not noticeable? The walls may be out of square but I would have thought that could have been allowed for, I believe a Trend jig was used
