has anyone fitted a kudos circular shower cubicle before. fitted loads of cubicles but not one of these. having a devil of a problem getting a leak free cubicle on the wall post bases. been told they are prone to this. can't understand why they design it that there is 6" of free standing glass either side of the bottom and top frames, that you then have to try and seal.
found the gaskets did not seal tightly in some areas, and the profiles did not really fit that well.
normally the wall plated i fit are c section and you get a dry seal through this. the kudos shower is just a flat fit, and unless to silicone everything you have gaps all over the place.
