- Joined
- 16 Apr 2019
- Messages
- 5
- Reaction score
- 0
- Country
Hello, first time on this page but I’ll do my best to explain my issue.
It all started when my boiler malfunctioned, ended up being the blower, the flame tube and the igniter.
After this was fixed by a professional after the system pressurized it started leaking out of the pressure relief, no big deal just thought it was air bound, so we relieved the pressure and it was fine....till a few hours later when it over pressurized again.
Now my uncle was a plumber and he came over and said that it was probably the water inlet valve and the back flow valve, i agreed and we replaced both and again, it was fine for a few hours and then over pressurized again.
Looked through some forums and found it could be a faulty expansion tank so i bought one and replaced and also figured it would be good to change the relief valve at the same time so i did and everything seemed great, we got the air out and the expansion tank and air bleeder on top was working great, until a few hours later and it over pressurized again.
I tried shutting the main valve for the water inlet off and let that sit over night after i drained and pressurized the system to the correct psi (15-20psi) and woke up this morning to again an over pressurized system and it was dropping yet again.
I’m at my wits end, it’s impossible to get my uncle out so I’m trying to figure this out but I’m lost at what more could there be to replace that would pressurize the system.
Any help is much appreciated
