Ladder Rad
7 Jan 2006
Bristol
I've recently installed a ladder rad in the bathroom, the pipework changed slightly but I'm sure it's still the same layout (we have one 22mm running under the floor with 15mm pipes off it to each rad). There is water in rad but it's cold, the pipes are hot till just after they branch off. Hot water cylinder and header in loft space so they are way above max height of ladder rad. Help! :?
Sounds like a one pipe system , if you put any bends between the 22mm pipe and the rad it just wont go around it because one pipe systems are s**t :lol:
There are indeed bends in the 15mm pipes coming from the 22mm pipe. I sall try to alter it so there isn't! Many thanks. Will post again if this doesn't work. Why did they do one pipe systems, can they be changed to a normal system without changing the boiler, and vice versa?
Just an old type of heating system it can be changed to a two pipe system without changing the boiler but it means a lot of repiping work ie adding another pipe all through the house
