Laminate board direction?
2 Nov 2014
Midlothian
Hello there.
I am going to install laminate in my new flat and do not know in what direction I need to lay the boards. The laminate will go in the 2 bedrooms, the hallway and the living/dining area.
Any suggestions?
View media item 84846
Thanks for your help!
yes id go the same way right the way through, you could use joint strips where the doorways are that would make life a bit easier
Thank you for that.
Although that was my first impression, i was a bit worried that it would not look nice in the hallway. Do you think it will be ok?
ive done hallways both ways, depends a bit on the pattern and type, as you don't have a natural light source in the hall I don't think it will make much difference, why not lay a few boards down and see how it looks, my main reason for suggesting starting where I said was it always looks better laid along the widest wall of the room and its a flat wall so will give you a good starting point. but I wouldn't change direction just for the hall I think it would look odd
