Greetings,
I have a query which someone may be able help.
Scenario: I plan to lay laminate flooring in my bungalow.
Front door opens into entrance hall (6ft X 10ft), straight head goes into living room and to the left(at 90 degrees) is a corridor (3 1/2 ft X 30 ft).
Now, I planned to lay floor running in from front door and flowing continously into living room . If i continue in this direction the flooring would run across the corridor, rather than running the length of it.
Would it be ok to lay the floor up and down the length of the corridor and butt it perpendicular to the floor running from the hall into living area.
Hopefully this makes sense !!
Thanks in advance,
gLo.
Thanks in advance,
gLo.
