Laying laminate flooring direction
28 May 2014
Aberdeen
I'm laying laminate flooring in my living room which is 16x11 do I lay towards the window which is 11ft or do I go the other way thanks
If boarded then run at 90 degrees to boards, hard floor then does not matter as much , slightly easier to run into a doorway than across a doorway to fit under the frame.Across the window will highlight undulation more than inline.
So, no firm rule.
I start at the corner furthest from the door if conditions allow.
