Landing edging
16 Apr 2006
Cardiff
Hi Anyone know how i would go about replaing the eding on the ladning, looks very similar to the treads on the starcase.
If i bought some would how would I round the edge of the wood? what tool would do this and what would I hire to do this?
i also want to replace the wood paneling on the side of the staircase wall inthe same wood, how would i do this? is it nailed or glued in?
Please reeally need some help here
have attached pic and labelled the edging and panelling im refer to as A and B
are you renewing the spindles?? if so the existing baserail could come up and you can renew it with pine. as for the rest it could come off and be renewed, just be careful what it is tied into. as you see im in cardiff myself if you want me to pop in and see if i can give you any advice id be happy to.
all the best
wayne
Hi Wayne
Basically its all being replaced, bit of a long story but the orignal newel post split and have had to saw it off and replace the newel turing, but eveything is to be replaced with richardburbidge system, the wall is being plastered this week so want to rip off the old wood to be replaced after walls plastered.
Does the floor edging on the landing have to be shaped by me or does it come already shaped?
Also for the wall panelling, can that be preshaped or would I have to do that and if so how :-)
any shaping you need to do can either be done with beading which can be glued or pinned on or can be routered, the baserails are preshaped. if you need something routered give me a shout and you could use my one.
