Laptop disconnecting itself from WiFi
26 Jun 2004
London
I have an ASUS X553S running Windows 10. Quite a nice laptop with a 15" display.
It logs into my WiFi whenever I turn it on as set to.
But after a couple of hours it disengages the WiFi and if I try to manually reconnect it says "Unable to connect". But does not show any reason why.
However if I just restart the laptop it immediately logs in automatically as normal.
Does anyone have any suggestions for such an unusual fault?
I regularly scan it for viruses with AVG and sometimes Malwarebytes too.
Title changed to be descriptive
Could it actually be a setting on your router - guest network?
Nozzle
Obtain a usb WiFi dongle for not much money and use it to get online, disabling the internal network card
Does the problem remain (it's not your laptop) or go away (could be your laptop)?
Are you by chance using BRSK as an ISP?
This is a common issue that we have, I'm told it's either the router or CGNAT that causes it.
This seems to be only on Community Fibre which is the network that I am usually using.
If it's common to an ISP, it would point more toward an oddity with the router they have supplied, but I still recommend you test with an alternative network adapter per the suggestion above - they aren't expensive
There may be a Community Fibre Facebook users group where you can also ask, they may know if it is a common issue like mine.
Else try to try logical steps to find where the issue is.
Does the same happen with phones, can you try a lead, another laptop, the USB dongle suggested above etc.
It does not seem to happen on another laptop which is used on the same wifi.
Since this laptop gives the "cannot connect" error then I expect it is a problem with my laptop.
How many times should I recommend you try another network card? (WiFi usb dongle, or use a cable to connect the router)
"It's a problem with the laptop" is too broad
well rebooting is overkill. It's prob windows doing powersvaing on the network card and if turning that off doesn't prevent it, then forcing a clean reconnect in terminal would prevent the need to reboot. You could easily automate that with a simple python script you double click on for convenience.
