I'm getting a garage floor laid in concrete soon, the size of the garage is 7metre by 8.5 metre, do I require an expansion joint or can this be laid as one slab, I'm unsure as its farily large and wouldn't like any cracks forming at a later date..
Normally you would get some shrinkage cracking on a slab that size, and traditionally a thin, shallow 'cut' would be made across the slab to control the cracking.
If you reinforce it with square mesh, that will reduce the tendency to crack, and you can also get a mix with polypropylene fibres, which reduces cracking.
If the base is firm and well-compacted, anti-crack mesh is usually best mid-height.
There are little plastic 'chairs' you can get to support the mesh in a few places while the mix is poured.
