Large pipe clamps
Like a Dragon then, I’m out. Doesn’t seem to be of any use what I’m looking for and posting.
Well, I believe we already went through that suggestion earlier in the thread. Thanks for suggestions though.
I've got one other line of enquiry pending from another suggestion on page 1 of the thread, a company which makes what they supply, they might be able to do something.
There are the exact, high quality, items required available from Clark Masts. They are expensive and the OP unwilling to pay for them.
I noted that the largest size of universal clamps from Britishpipeclamps were around the £30 mark each, plus delivery. So if they would do two bespoke sizes they'd likely be similar in cost to Clarks.
A steel fabricator / blacksmith might make a 'copy' of that universal clamp if requested in the required sizes; but again time is money and it may not be that cheap to do it.
Yes it was your link to Britishpipeclamps which I noticed they do an ideal clamp, just not in the size. Interestingly the skip the size I want and go much bigger. But I'll see what they say at least.
Here we are :giggle:
Thanks for the link to BPC Engineering, they happily custom made some (y)
Now that I've seen the clamps that you bought, would have mast coupler clamps served you well? If you had stated the mast OD several members in here would have come up with good suggestions. The tube OD would determine possible clamps; without the size everything is guess work
On Page 1, Post 5, I did state the OD, which is why regular mast coupler clamps would not work.
