Lath wire help required.
18 Aug 2004
Could someone tel me if this product is suitable for exterior lathing of an external panel above my window. The panel is already made up with 18mm exterior plywood covered in roofers felt. I'm not sure of the lath wire type to use upon this prior to rendering.
Expamet Galvanised metal lath sheet.
If not could you please recommend a product or even better a link to the product. Thanks.
Thats the kiddie... cut with an angle grinder its bloody sharp when you catch the hands cutting with snips. if you are using angle bead then not regular galvanised as it will rot away plastic or stainless s.
