Hi, any advice on the above please.
We have a fairly large concrete slab and several box rooms off giving an area of about 10mtrs x 5mtrs.
The room is ground floor and we have built over, the cieling height having been raised at this time so ideal to raise the floor and insulate.
The project has gone over spend so needs to be done cheaply,(hence no under floor heating), but without cutting corners. The slab is very flat, on visqueen so dry.
So, I propose to add a futher layer of 1000 visqueen across the area and upstand to the walls, I" jablite around the edges (1 x 3), and the floor area covered in 2 " jablite. This will then be over boarded in P5 V313 chip.
The question is any issues with this?
And is any additional battening requred under the bording othe than at the only finishing edge?
Thanks for any help, although this job gets started today so sooner than later would be great.
