- Joined
- 27 Jan 2008
- Messages
- 27,706
- Reaction score
- 3,359
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have in the home a selection of batteries, the theory may say use a smart charger and leave it on the battery, but in practice only have two smart chargers, so I need to move it from battery to battery, and with lock down cars are not being used, so also looking at charging batteries in the cars, mobility scooter, caravan etc. From 7 Ah used to power my radio, to 12 Ah for jump start/air compressor, to 35 Ah mobility scooter those are are VRLA, to 36 Ah in small car sealed, and 90 Ah sealed in larger car and 90 Ah AGM in stop start car I have a load of lead acid batteries.
The car if in use I can forget, but at the moment I have one car which has hardly moved since March, I have recharged the battery around 3 times to date, the 4 x 4 I use a little more, but still not much, again recharged battery once or twice to be on safe side, and the little Honda Jazz has been used the most and also recharged the most, and on Thursday the battery failed. It was not in best condition and I knew every three weeks it needed a charge, so not a big surprise when it failed, so renewed.
So drove around 50 miles with new battery, then put on charge Friday afternoon, I expected either it to take a lot of charging, showing the car was not charging, or very little, but the charger has put in around 15 Ah, not enough to say some thing wrong with car charging system, but a lot more than expected for a new battery. Lights were on so at least 15 amp being used so 50 miles nearly 2 house so if not charging would be nearly completely discharged, and charger showed 12.6 volts when put on battery, so clearly neither fully charged or flat, but no idea how well charged when I got it, since sealed not filled at motorist shop, so could have been sitting around for a long time. Starting engine voltage showed 14.5 volt, seems a little high but within limits.
It seems likely a car alternator will go over static charging voltage as it needs to charge battery in a very short time, I know the open circuit voltage for a two bobbin regulator like the Lucas RB106 or RB108 was 16 volt, it would never hit that with a battery connected.
However the Lidi charger will step down the charge rate with most batteries and hold them at 12.9 volt, as it drops to 12.8 volt it will switch up charge rate until 14.4 volt and then off or down again depending on battery size selected. But take the battery off charge, and it will when put back on can take some time at 14.3 volt before it switches down again, so each time a battery is put back on charge it is held at some time at the higher volts.
At 12 Ah the charger switches off, and at 90 Ah the charger can't exceed 12.9 volt at 0.1 amp, so alternates between 0.1 amp and 0.8 amp. It is the 35 Ah battery which is between the two so 0.1 amp will cause it to rise above 12.8 volt, but it is unlikely to hit 14.4 volt to switch it off.
So if held at 13.8 volt I am not over worried, but mothers old chair lift would hold the battery at 15 volt, and if used daily the batteries would last around 4 to 5 years, but if hardly used, then 2 years was around the maximum as over charged. Father-in-laws chair lift the batteries lasted over 10 years until in error he turned it off, and charge voltage a lot lower at around 13.4 volt. Seen the same with intruder alarms, 0.4 volt can means difference between 2 and 4 years life.
So I know once I take a battery off charge, if not being used, I can leave it for a month before charging again, but leaving it a year will likely cause damage, but where is this sweet point, and does if battery flooded or AGM (VRLA) affect how long, and what about sealed but not AGM? I would think looking at 1 to 3 months between refresher charge, but that is a guess.
